Zactomodels | 1/32 Su-27 Early Tail Stinger Conversion Set
Reviewed by Randy Bumgardner
Zactomodels, known for their upgrade and conversion sets for large scale modern jets, continues their line of upgrades for the Trumpeter Su-27. This conversion will backdate the stock kit to an early model Flanker B.
The set consists of a single piece tail molded in beige resin. A strip of plastic is also provided for the antennae on the tail. The detail is well represented and finely done. The conversion is accomplished by cutting along panel lines and dropping the new tail stinger into place. The instructions are very easy to understand with plenty of diagrams. A measurement diagram for the antennae is also provided.
If you are looking to update and backdate your big Flanker from Trumpeter, then I highly recommend this conversion to make your kit just a little bit different.
Review sample provided by Zactomodels. Thank you!
© Randy Bumgardner
