Eagle Editions | EC75; Bf 109 K-4s in 1/32nd Scale JG 27, JG 53
Reviewed by Mark Proulx
This is a review of EC#75, the second of two new 1/32nd scale decal sheets for the Bf 109K-4 from Eagle Editions. Those interested in reading a review of EC#74 may find it elsewhere on LSP.
As with the earlier sheet, four exciting new schemes are now available. The first K-4 is Black Chevron of Stab III./JG 27. The pilot was unknown. The aircraft is finished in a scheme of RLM 76/slightly darker than normal 75/83. The Home Defense Band was RLM 25 identifying the attachment to JG 27. Some simple modifications to the Hasegawa kit are required as no external trim tabs are visible on the rudder of this aircraft. In addition, the white of the fuselage cross needs to be toned down slightly by the modeler with RLM 83.
The next subject is the Bf 109K-4 of Lt. G. Landt. Identified as Yellow 1, this aircraft was assigned to 11./JG 53 in April 1945. The scheme consisted of RLM 76/lighter than normal 75/83. A large black number 2 was also visible on the fuselage side beneath the Yellow 1. This is not duplicated with a decal, but the modeler is supplied with a scale template to spray the numeral two upon the fuselage side.
Next is Black 8 from 14./JG 53. This aircraft displayed a pattern of RLM 76/75/83. The fuselage appeared very dirty and slightly darker in the application of RLM 75.
The final option is White 10 from 9./JG 27. This 109 was finished in a pattern of RLM 76/75/83. The pilot and werk number are unknown for this, and most other aircraft on this sheet.
Color side and upper surface profiles are supplied. Given the complex nature of late war German schemes, this information is crucial if you wish to accurately portray a Bf 109K-4. An example of this is identified in the extensive text highlighting the different shades of RLM 75. This color grew increasingly lighter as the war progressed. Documents explaining these features were all destroyed by the paint manufacturer near wars end as the Russians approached. Consequently, it is unknown if a new paint designation existed for this color or if this was a simple modification to RLM 75. The instructions identify the two JaPo books used as references in the creation of this decal sheet. I would highly recommend these books as the best references about the Bf 109K that are currently available. These two books are reviewed here and here.
The Bf 109 K is a fascinating subject to many and serves as a prime example of chaos faced by the Luftwaffe late in the war. Extensive gaps in information exist and can be no more evident than the fact that the pilots of three of these aircraft remain unidentified. These new decals are a great addition to the Hasegawa Bf 109 K-4 and I recommend them without hesitation.
Review Sample Compliments of Eagle Editions.
© Mark Proulx 2004
