Aerocraft | Messerschmitt Bf 108 Brass Undercarriage Set for Eduard Kit
Reviewed by Andrew Birnie
While having a good look at the sprues of the recent Eduard Bf 108, one thing that struck me was how spindly the undercarriage legs are, and the angle at which the are to be mounted rang out troubles ahead, however like the cavalry coming over the hill to save a precarious situation is this set from Aerocraft Models, finely cast in brass, the rear leg is longer than the kit version to help gain a more secure attachment, there is a little clean up required of the casting block on the axle, but it's just a simple cut with a razor saw.
If you have the kit this really is a must buy.
Review copy courtesy of Aerocraft Models.
Available from Aerocraft Models.
© Andrew Birnie, 2020
This review was published on Saturday, July 11 2020; Last modified on Saturday, July 11 2020
