Fantasy Printshop | FP1080: RAF 8" Serial Numbers & Letters WWII and 1946 Style
Reviewed by Kevin Futter
Fantasy Printshop has released a set of decals in 1/32 scale for RAF 8" serials in WWII and 1946 style. The set contains two A5 sheets, one printed in dull red, and the other in black:
Apart from the printing colour, the sheets are otherwise identical. The letters and numbers are provided in a variety of styles, so you'll need to check your references to determine which style is applicable to the subject you're modelling. Each letter style is supplied in triplicate, while the total for each number style included appears to vary with the style itself; presumably this is based on how common a particular style was in use.
Print quality and colour density are both excellent, and with only simple designs and a single colour used on each sheet, registration is a non-issue.
A handy set of utility decals from Fantasy Printshop, done to the company's usual high standard. What more could you ask for?
Thanks to Fantasy Printshop for the review sample.
© Kevin Futter 2019
This review was published on Saturday, October 12 2019; Last modified on Saturday, October 12 2019
