Aerocraft Models | Cessna O-2A Skymaster Undercarriage Set
Reviewed by Andrew Birnie
When I received, and reviewed Roden's O-2 Skymaster kit last year, it was very apparent that the plastic used was quite flexible, and as a consequence the main undercarriage spar would splay under the weight of the kit.
To the rescue comes Aerocraft Models with a brass replacement undercarriage set, consisting of three parts; main undercarriage spar, front undercarriage, and last but not least an axle for the front undercarriage. All very nicely cast requiring only a minimum amount of clean up.
If you have the kit, or intend to, this neat set is a must.
Set kindly supplied by Ali of Aerocraft Models.
© Andrew Birnie 2018
This review was published on Tuesday, June 12 2018; Last modified on Tuesday, June 12 2018
