Jerry Rutman | 1/32nd Scale P-38E/F Conversion
Reviewed by Chris Sherland
Rutman products hits a huge home run here with this E/F conversion for the Trumpeter P-38 kit. This is all one needs externally to turn the Trumpeter L into an early war Lightning. This set is beautiful, and a conversion can be seen at the Modeling Madness site.
(image used courtesy of Tom Cleaver)
The set comes with 2 chin intake plugs, and 4 radiator scoops that are all modified to E/F specifications, as well as the "smooth" windscreen common to the earlier Lightnings.
Be warned however, that there are a few other tasks awaiting the brave converter! The L model has dive flaps that must be removed, as well as a vastly different cockpit configuration. Rutman Products does produce a cockpit set for the earlier Lockheed fighter, but the dive flaps must be remedied by the modeler.
Thanks to J Rutman Products for the review sample.
© Chris Sherland 2004
