Zoukei-Mura | 1/32 Sd.Kfz.2 Kettenkrad Photo Etch
Reviewed by Mike Swinburne
Around the same time Zoukei-Mura released their epic He 219 kit, they also released a Kettenkrad in 1/32 scale, the first of its kind in this scale, along with several accessories for the small tracked airfield vehicle.
One of the accessories is a photo-etch detail set made by Aber for Zoukei-Mura. This contains approximately 67 PE parts, 4 brass parts for handrails, the gear shift lever, and what I expect is a hand brake, and one small film/acetate sheet for the gauges. Comparing to the kit parts, you definitely get some nice additional detail here!
The set comes packaged in a clear thin plastic box which opens on the top, which is now quite standard for ZM aftermarket sets but still not one I'm used to seeing contain a simple flat photo-etch fret.
Instructions are in Japanese but the diagrams are quite easy to follow, so anyone with some experience using photo-etch should have no difficulties in correctly using the parts. Highly recommended!
© Mike Swinburne 2014
This review was published on Wednesday, March 19 2014; Last modified on Friday, March 28 2014
