Barracuda Studios New Releases April 2023
Barracuda Studios is proud to announce 12 new products in all 4 scales! These products are now up on the Barracuda Studios website and ready for purchase.
Our new 3D Spitfire control column (early and late styles) is super detailed and accurate, with fine details never produced before.
We hope you find these as cool and exciting as we do!
Happy modelling! Roy.
BR24501 1/24 Spitfire Early Style Control Column
This set is for Spitfire Mk Is and Vs fitted with machine guns only. If it has an eight gun A wing, this is the set for you. The spade grip features the round housing for the trigger, as well as an attached brake lever.
This control column is offered in 3 versions. With and without gun camera button and a third version with the ailerons deflected. Perfect for your Airfix or Trumpeter Mk I or Mk Va. A quick and easy upgrade that will be highly visible through the open door. 3D printed.
CAD design by Mike O'Hare.
BR24502 1/24 Spitfire Late Style Control Column
This set is for Airfix's superb new 1/24 Spitfire Mk IX. This stick is also suitable for every Spitfire from The Mk Vb through the Seafire FR 47. The spade grip features the rectangular housing for the 3 position trigger switch, and a molded on brake lever.
This control column is offered in 3 versions. With and without gun camera button and a third version with the ailerons deflected. A quick and easy upgrade that will be highly visible through the open door. 3D printed.
BR32503 1/32 Spitfire Early Style Control Column
This is for Spitfire Mk Is and Vs fitted with machine guns only. If it has an eight gun A wing, this is the set for you. The spade grip features the round housing for the trigger, as well as an attached brake lever.
This control column is offered in 3 versions. With and without gun camera button and a third version with the ailerons deflected. Perfect for your brand new Kotare Mk I Spitfire, which is gorgeous all on its own! Will also improve the Revell, Hasegawa and Trumpeter 1/32 Spitfire Mk I or Mk Va kits. A quick and easy upgrade that will be highly visible through the open door. 3D printed.
BR32504 1/32 Spitfire Late Style Control Column
This stick is suitable for every Spitfire from The Mk Vb through the Seafire FR 47. The spade grip features the rectangular housing for the 3 position trigger switch, and a molded on brake lever.
This control column is offered in 3 versions. With and without gun camera button, and a third version with the ailerons deflected. A quick and easy upgrade that will be highly visible through the open door. A quick and easy detail upgrade for Tamiya's superb 1/32 Spitfire Mk IX, VIII, and XVI, as well as the Revell IX, Trumpeter Vb, and any number of conversions. 3D printed.
This article created on Monday, May 01 2023; Last modified on Monday, May 01 2023
