Eleven New LSP Products from Barracuda Studios
Barracuda Studios is proud and happy to announce 11 new products for immediate release.
Over the past few years, we have gotten a good number of requests to replace the rubber tires for the classic 1/24 Airfix Spitfire, Me 109E and Hurricane kits. These new wheels sets fill that gap with highly detailed and accurate new wheels. The rubber tires are not popular with modelers, as they can dry out and split. They also don't take paint well and they are a little sticky, and tend to attract and hold on to dust and grit.
We have also released some further upgrades for the Revell Bf-109G-6, in the form of corrected upper cowls with better detail and proper spacing between the gun troughs. The Revell Spitfire Mk IX kit is nice, but it is lacking radiator intake and exhaust ramps. This set corrects that design oversight. We also have a new undercowl with a proper rendition of the Aerovee carburettor intake.
Finally, a pair of vacform sliding hoods for the Eduard Fw-190 kits, both new and old tool.
BR24449 1/24 Spitfire Mk. I - IX Five Slot Mainwheels
This set contains a pair of resin cast accurate mainwheels, featuring fine tire beading, readable tire data, and a super detailed 5-slot wheel hubs. Designed to replace the rubber tire/plastic wheel hub assembly found in the Airfix and Trumpeter Spitfire Mk. I and V kits. A fast and easy upgrade. Patterns designed by Gerry Mos.
BR24450 1/24 Spitfire Mk. I - IX Covered Mainwheels
This set consists of a pair of resin cast accurate mainwheels, featuring fine tire beading, readable tire data, and a super detailed covered 5-slot wheel hubs. The covered hubs were used to keep mud and dirt out of the wheels hubs.Designed to replace the rubber tire/plastic wheel hub assembly found in the Airfix and Trumpeter Spitfire Mk. I and V kits. A fast and easy upgrade. Patterns designed by Gerry Mos.
BR24425 1/24 Hawker Hurricane 4 Slot Mainwheels
This set contains a pair of resin cast accurate mainwheels, featuring fine tire beading, readable tire data, and a super detailed wheel hubs with separate uplock lugs. Designed to replace the rubber tire/plastic wheel hub assembly in the available kits. A fast and easy upgrade for the Airfix and Trumpeter Hurricane kits. Patterns designed by Gerry Mos.
BR24435 1/24 Bf 109E/F Mainwheels with Ribbed Tires
This set contains a pair of accurate resin mainwheels featuring super detailed spoked hubs, subtly ribbed tires and readable logo and data as fitted to the Bf 109E and F series aircraft. Replace the problematic rubber tires found in both the Airfix Me 109E. Patterns designed by Gerry Mos.
BR32157 1/32 BF 109G-6 Upper Gun Cowling (Standard)
This set consists of one detailed, accurate upper cowling. This set improves the detail and corrects the spacing of the machine gun troughs, which are too close together on Revell’s Bf 109G-6 kit part. For non-Erla built Bf-109G-6s. A one piece, easy to install correction for the Revell kit. Pattern by Gunnar Jansson.
BR32158 1/32 BF 109G-6 Upper Gun Cowling (Erla)
This set consists of one detailed, accurate upper cowling specific to the Erla built 109G-5 and G-6 aircraft. The gun troughs are different on these Erla built machines. Erla upper cowlings have a rectangular panel line around them. This set also improves the detail and corrects the spacing of the machine gun troughs, which are too close together on Revell’s Bf 109G-6 kit part. A one piece, easy to install correction for the Revell kit. Pattern by Gunnar Jansson.
BR32461 1/32 Spitfire Mk IX Late (Aerovee) Carb Intake
Contains a new resin lower engine cowling with accurate, detailed, late style Aerovee carburettor intake to improve the simplified, inaccurate Revell Spitfire Mk IX parts. A quick and easy one-piece replacement. For the Revell Spit IX kit. Mastered by Roy Sutherland.
BR32340 1/32 Spitfire Mk. IX Wing Correction (Revell)
This set contains a pair of new resin wing sections featuring accurate intake & exhaust ramps to replace the flat wing sections in the kit. Also included are new detailed radiator fairings and radiator faces to replace the less detailed kit parts. Clear, illustrated step by step instructions walk you through the installation. A real improvement for the Revell kit. Master patterns by Roy Sutherland.
BR32448 1/32 Bf 109F/G Separate Control Surfaces
The set consists of new resin ailerons, elevators and standard rudder for the Revell kit. Why did we make them? The kit parts have nice fabric rib tape detail, but it is overstated and the trailing edges are quite thick when assembled. It takes a good bit of careful sanding and shaping to thin the edges and make the fabric detail properly subtle. We have done it for you. For Revell's Bf 109G series. May fit other kits. Master patterns by Roy Sutherland.
These new products are up on the website now and ready to be ordered.
Happy Modelling!
This article created on Sunday, May 02 2021; Last modified on Sunday, May 02 2021
