New 1/32 Products from Barracuda Studios
Barracuda Studios is proud and excited to announce 4 new products in 1/32 scale (plus another 6 in smaller scales).
All products are now up on the Barracuda Studios website and ready for ordering.
BR32393 1:32 Bf 109GK Tall Tailwheel Set
This set contains one accurate and very strong lost wax cast brass tall tail strut and two styles of detailed tailwheels in resin, both smooth and radial tread tire versions. This brass strut will not bend over time like white metal can. Can be fit to all late model Bf 109G/K kits in 1:32 scale. A quick and easy upgrade that will assure no more broken tailwheels. Designed by Gunnar Jannson.
BR32436 1:32 Bf 109E/F Mainwheels with Ribbed Tires
This set consists of a pair of accurate resin mainwheels featuring super detailed spoked hubs, subtly ribbed tires and readable logo and data as fitted to the Bf 109E and F series aircraft. Patterns designed by Gerry Moss.
BR32441 1:32 F8F Bearcat Propeller Correction Set
Contains an accurate Aeroproducts Bearcat prop, consisting of four accurately shaped blades and detailed hub with backplate, to replace the inaccurate prop assembly in Trumpeter’s Bearcat kit. Props can make or break the look of a model. An easy and highly visible upgrade. Master patterns by Danny Lauderdale.
BR32442 1:32 A-1 Skyraider Propeller Correction Set
Contains an accurate Aeroproducts Skyraider prop, consisting of four accurately shaped blades and detailed hub with backplate, to replace the inaccurate prop assembly in Trumpeter’s Skyraider kits. This propeller was also fitted to some warbirds and Reno Unlimited Air Racers. Props can make or break the look of a model. An easy and highly visible upgrade. Master patterns by Danny Lauderdale.
This article created on Sunday, November 15 2020; Last modified on Tuesday, November 17 2020
