Barracuda Studios New Product Announcement
Barracuda Studios is proud to announce the release of 12 new products spread over 4 scales, from 1/24th to 1/72nd. These products are available for sale on our website now.
http://barracudacals.com/products.php?cat=33
Listed below are the LSP items.
BR24271 1/24 RAF Groundcrew Assembling Rocket
This set of crew figures represent two RAF Armourers assembling a 3" rocket as fitted to Typhoons, Mosquitos, Beaufighters and other RAF aircraft during WWII. They are stunningly detailed and artfully posed by Vince Chmielewski. They have been completely designed in CAD, and the detail must be seen in person to be fully appreciated. The set consists of two crewman, a 3" rocket with 60 lb. HE warhead, 2 mounting clips and a small sheet of decals for the rocket stencils. To be posed alongside your Typhoon or Mosquito, or as a standalone vignette.
BR32394 1/32 Ta 152H Mainwheels
This set consists of new resin mainwheels for Ta-152H and some later production Ta-152Cs. They feature detailed tires with fine tire beading, logo and data, and accurate hub detail with mounting points for the front hub brake cable, which is supplied as fine black wire. A big and easy detail upgrade for your Zokei Mura or PCM Ta-152 kits. Designed by Gunnar Jansson.
BR32262 1/32 Mosquito WWII Radio Upgrade Set
This set consists of a pair of accurate, superdetailed British T1154 (transmitter) and R1155 (receiver) radios with separately molded knobs for ease of painting, and full stencil, placard and dial decals. Electrical connectors are also supplied along with full color, illustrated instruction that includes a wiring diagram. For your 1/32nd scale WWII era Mosquito or can be displayed on a bench in a diorama setting. Suitable for many British WWII multi-place aircraft. Designed by Kerry Carlyle.
BR32409 1/32 Lancaster Mainwheels - Smooth Tire
This set contains accurate resin mainwheels with smooth tires, detailed hubs, and fine tire beading. Smooth tires were fitted to the almost all Lancasters during WWII. This set also corrects some noticeable errors with the HK models wheels, which are wrong in cross section and the hubs are lacking both depth and detail. An easy and very noticeable upgrade for the 1:32 HK Models kits. Designed by Mike Swinburne.
BR32410 1/32 Lancaster Mainwheels - Block Tread
This set contains accurate resin mainwheels with staggered block tires, detailed hubs, and fine tire beading. Block tread tires were common among post war Lancasters. They are not appropriate for wartime aircraft, unless you just like the look better. This set also corrects some noticeable errors with the HK Models wheels, which are wrong in cross section and the hubs are lacking both depth and detail. An easy and very noticeable upgrade for the 1:32 HK Models kits. Designed by Mike Swinburne.
BR32411 1/32 Lancaster WWII Radio Upgrade Set
This set consists of a pair of accurate, superdetailed British T1154 (transmitter) and R1155 (receiver) radios with separately molded knobs for ease of painting, and full stencil, placard and dial decals. Electrical connectors are also supplied along with full color, illustrated instruction that includes a wiring diagram. For your 1/32nd scale WWII era Lancaster or can be displayed on a bench in a diorama setting. Suitable for many British WWII multi-place aircraft. Designed by Kerry Carlyle.
This article created on Saturday, August 24 2019; Last modified on Saturday, August 24 2019
