P-39D1 BE Paper Model (KW Model)
By Tomasz Kalata
This was my debut build on LSP.
I set the bar for myself a little bit higher than I felt comfortable, and picked a quite detailed paper kit, the P-39 D1 BE published by KW Model. The model is in 1:33 scale which is very common for card kits, and depicts aircraft with the number K 41-38359, which was flown by LT. George Welch and belonged to 8th FPG USAAC operating in New Guinea.
I used laser-cut formers, a high resolution instrument panel printed on photo paper and a vacuformed canopy, all available as add-ons from the kit’s producer.
In the first step of the build I applied to all sheets a coat of flat Model Master lacquer to seal in the print and give it extra protection during the assembly.
I started with assembling the wings structure which was skinned next. I replaced printed details of the navigation and landing lights with scratch build ones. The assembly of the fuselage was done section by section.
To play it safe I restrained myself from any extensive detailing in the cockpit, relaying mostly on parts provided in the kit. My scratch work was limited to seat-belts made of metal foil and a few details on the instrument panel.
The canopy framework gave me some headaches and I’m not completely happy how this element turned out. The tail was added at this stage.
The wheels were made of laminated discs of cardboard, sanded and painted. Unhappy with the kit’s version of the front wheel fork I replaced it with scratched one.
I used parts from the kit for exhaust stubs, but modified them by adding weld beads, and painting them with MM burned metal. The stubs were finished with soft pastels hardened with fixative.
In the end I experimented a bit with weathering adding paint chips and scuff marks with colored pencils. I used chalks to simulate exhaust stains, and dirt. Since it was my first attempt at weathering I aimed at rather subtle effect.
It was my first experience with a high-end paper kit and I’m quite satisfied with the end results. I made a couple of mistakes, which I was not able to correct. Not every element turned out the way I hoped, but I treated this build as a learning experience on which I can build on later. Had a lot of fun too!
© Tomasz Kalata 2011
This article was published on Wednesday, November 23 2011; Last modified on Saturday, May 14 2016
