Duarte Models 3D Printed EMB-312/T-27 Tucano
By Daniel Iscold
This is the second T-27 I have built, using the kit produced by Fábio Duarte. As a reference, I used João Paulo Morales' spectacular book, an essential resource for this build.
This time, before gluing any parts together, I first test-fitted and adjusted the landing gear components. Once assembled, the model must sit exactly 4.5 cm above the display base, measured from the wingtips. To add weight to the nose, I used approximately 77 grams of Zamac pellets, secured in place with polyurethane resin. Yes, the model becomes extremely heavy, but the bronze landing gear legs can easily support the weight of both the resin and the ballast placed inside the cavity corresponding to the aircraft's engine.
Following my suggestion, Fábio made the instrument panel faces open, allowing modelers to apply the decals from behind, giving the instrument panel a much more realistic appearance. I chose to finish the model in the colors of the Air Defense Group (GDA), based in Anápolis, Goiás, Brazil. João Paulo informed me that the GDA may not have used rocket pods. In this case, they were installed purely for modeling purposes and have no historical significance.
Without a doubt, the most challenging part of this kit is cutting and fitting the vacuformed acetate canopy, as well as assembling it onto the resin frame. Another annoying little thing in this model are the extra thin wing and tail assembly rear edges. During the build process they broke many times. Extra care is necessary to keep them straight without breaking. I placed two brass tubes through the fuselage as wing spars, in order to reinforce the wing - fuselage fit.
This time, I decided to build the model with the canopy closed, preserving the beautiful aerodynamic lines of this aircraft.
I hope you enjoy it, my friends!
© Daniel Iscold 2026
This article was published on Friday, November 27 2026; Last modified on Friday, November 27 2026
