Hasegawa 1/32nd P-40M
By Glijn Van Driessche
After a very long time I finally finished this kit of the P-40M.
While the Hasegawa P-40 kits are modular to allow for multiple variants, this design requires careful filling and sanding of seams that do not fall on natural panel lines. That and a lot of self-inflicted problems caused the long build period.
Almost all markings are sprayed on except the plane’s name on the nose. This is the result; I hope you like it.
Thankfully, it is finished now so I can put it away.
© Glijn Van Driessche 2026
This article was published on Thursday, March 19 2026; Last modified on Thursday, March 19 2026
