Halberd Models 1/32 Curtiss SC-1 Seahawk
By Jean-françois Boissy
Here is my latest build, a lovely kit.
This kit is very well designed. I had some problems closing the fuselage, but by reducing the diameter of the engine I was able to close everything up. Maybe it's my fault?
The float landing gear supports are, in my opinion, a little light for the weight of the kit; we'll see if over time they will hold up.
Be careful working with the resin, which is quite soft.
© Jean-françois Boissy 2025
This article was published on Thursday, October 30 2025; Last modified on Sunday, November 02 2025
