Dragon/Cyber Hobby 1/32 Messerschmitt Bf 109E-3
By Tolga Ulgur
This is Dragon’s Bf-109E-3 with the markings of StabI./JG53 at Wiesbaden-Erbenheim in November of 1939. It was flown by Dr Erich Mix. Which I finished some months ago.
I used a Quinta Studio cockpit set and a Quickboost seat in the cockpit. Exhausts were replaced with the Reskit exhaust set.
This is an example of JG53's experimental camouflage scheme at this time. Painting was done with Gunze acrylics. The upper surfaces were painted in RLM 71/02/63, and the lower surfaces are RLM 65.
For more information, you can check out my build thread in the Work in Progress forum.
© Tolga Ulgur 2024
This article was published on Friday, October 25 2024; Last modified on Saturday, October 26 2024
