Hasegawa 1/32 Ki-61
By John Kim
Here is my recently completed build of the Hasegawa 1/32 Ki-61 I kit converted to a Tei variant.
I used the Wolf Pack conversion set, which featured a lengthened resin nose and other bits. Also used on this build was the Aires resin cockpit set.
Most of the markings, including the tail emblems, were painted using custom masks produced on the Silhouette Portrait cutter.
The build, from start to finish, can be found by checking out my build thread in the Work in Progress forum.
© John Kim 2024
This article was published on Thursday, January 25 2024; Last modified on Sunday, January 28 2024
