Tamiya 1/32 Spitfire Mk IX
By Dirk Devijver
This is the Spitfire MK.IX, MA408/CG flown by Wg. Cdr. F. Gray in Sicily.
The Tamiya parts fit perfectly, I encountered no difficulties during construction.
The model was sprayed with Mr. Paint and weathered with Abt 502 oils. Cockpit sprayed with MRP and the details are painted with Vallejo. Extra pipes were added to the engine.
As always, no decals have been used, all the stencils and markings were made with the airbrush masks from 1ManArmy. The command flag off the Wg. Cdr. is also spray painted with a 1ManArmy mask.
© Dirk Devijver 2023
This article was published on Sunday, December 03 2023; Last modified on Sunday, December 03 2023
