Wingnut Wings 1/32 Rumpler C.IV, Converted to a Kaiserliche Marine Rumpler 6B.1
By Kent Karlsen
Born out of a requirement of the Kaiserliche Marine (German Imperial Navy) for a seaplane fighter, the Rumpler 6B was, like its contemporaries the Albatros W.4 and Hansa-Brandenburg W.9, an adaptation of an existing landplane design. In Rumpler's case the new floatplane fighter was based on the company's two-seat C.I reconnaissance aircraft. The modifications included adding a forward stagger to the wings, removal of the second (observer's) cockpit and fitting a larger rudder to offset the increased side area caused by the addition of floats. In the production aircraft, the area of the horizontal tail surfaces was also slightly reduced. The armament consisted of a fixed, forward-firing 7.92 mm (.312 in) LMG 08/15 "Spandau" machine gun mounted on port side of the engine block.
The initial version of the fighter was the 6B1. A total of 39 of these were produced, with all but one of the number having been delivered by the end of May 1917. A new version of the basic design, the 6B2, was introduced in October 1917. These aircraft retained the Mercedes D.III engine, but otherwise they were based on the C.IV, with larger dimensions and more rounded horizontal tail surfaces. In spite of the decrease in performance, 49 of this type were delivered between October 1917 and January 1918, during which time the remaining 6B1 also left the factory.
© Kent Karlsen 2021
This article was published on Saturday, February 13 2021; Last modified on Saturday, February 13 2021
