Revell 1/32 Hawker Hunter FGA.9
By Paul Ward
From what I’ve read this kit is almost 20 years old now – but it’s a real pleasure to build with no real issues.
The only upgrade I used was for the cockpit which, in hindsight, was a bit of a waste of time as the kit pit is perfectly usable. I had hoped to use alternative decals but they went missing in the post … and the kit decals turned out OK. Paints used were mainly Tamiya with the finish being their semi-gloss varnish. Panel lines were marked out using Mig products.
© Paul Ward 2017
This article was published on Tuesday, October 10 2017; Last modified on Tuesday, October 10 2017
