Fly 1/32 Hurricane Mk IIc - A Merlin in Russia
By Henrik Redin
Here is the result when we mix a Englishman with the Soviet union. A well used Hurricane in the cold landscape of Murmansk.
Some info of the fly 1/32 Hurricane kit. It is a shortrun. The fitting is quite good. Some minor errors. And please DRY FIT every part before assembly,You need sanding and grinding. This model is Out Of The Box. The only thing added is brake lines Insignias and markings are painted with airbrush.
Model Factoid:
- Fly Hurricane Mk IIc
 - Painted with Gunze acrylics and Tamiya acrylics
 - All bare metal is painted with Alclad II
© Henrik Redin 2017
This article was published on Wednesday, February 08 2017; Last modified on Wednesday, February 08 2017
