Hasegawa 1/32 Bf 109G-14
By Bob Laskodi
The tarp is what you do when you dump Tamiya Extra Thin all over the windscreen at the end of the build! I've actually wanted to try it since I've seen some pictures of aircraft having the canopy tarped in real life and wanted to see if I could pull it off and this seemed like a good time to try it.
© Bob Laskodi 2016
This article was published on Wednesday, August 24 2016; Last modified on Wednesday, August 24 2016
