Hasegawa 1/32 Nakajima Ki-84 Hayate/Frank
By Vaclav Klimt
Finished Hasegawa Hayate, build thread in the forums. Used Big-Ed from Eduard, used almost everything except flaps, Just after finishing found Profimodeller brass turned cannon barrels and pitot, it happens...sometimes...usually... Gunze C exclusively, used masks made by myself so only 5 decals came from the kit, Tamiya enamel washes + mix of oils, Uschi Van Der Rosten antenna wire, the thickest one, but I'm quiet dissatisfied because it's not round in profile, rather flat, it's more obvious when painted, I ordered middle one, hope it will be better.
© Vaclav Klimt 2015
This article was published on Thursday, September 24 2015; Last modified on Monday, March 28 2016
