Czech Model 1/32 T-33A
By Mark McAllister
Not a bad kit, fit was pretty good, detail good if a little soft in areas, plus the usual short-run kit issues. I used the AMS resin cockpit (which uses the kit instrument panels) and Caracals decals. Paint is MM enamels, overall ADC Gray with a semi-gloss/satin clear-coat to soften the glare. since the decal scheme depicts an ANG bird from the mid-70s I figured the airframes would be clean enough to eat off of so I did no weathering.
© Mark McAllister 2015
This article was published on Sunday, August 23 2015; Last modified on Saturday, March 05 2016
