Trumpeter 1/24 A6M2-N Rufe
By Mark McAllister
I've had the Trumpeter Rufe for quite a while (not the oldest in the stash, but close!). No aftermarket, because there is none out there. Fit was surprisingly good, and easy and quick build. Probably not even close on the paint. I chose not to over-weather it - my research showed that the dark green IJN paints seemed to flake quite a bit but the IJN Gray didn't. I've got quite a few other builds needing more time and attention. This one was a build to have fun building!
© Mark McAllister 2015
This article was published on Sunday, March 08 2015; Last modified on Sunday, March 08 2015
