Hasegawa 1/32 Fw 190D-9 "White 12" 5./JG 301, Bad Langensalza
By Bevan Brooks
This is Hasegawa's Fw 190D-9 built from the box. I added rivets, extra plumbing to the engine, seat belts from lead wire, brass tubing gun barrels and invisible mending thread for the antenna wire. Happy with the results although the photos could do with some work!
© Bevan Brooks 2015
This article was published on Friday, February 20 2015; Last modified on Friday, June 02 2017
