Eduard 1/32 Bf 109E
By John Bardwell
I finished this one this evening. It started out as the Eduard ProfiPak E-7 Trop but wound up as a E-4 Jabo. I tried to use the Aires cockpit set but it would NOT fit correctly. All I used from it was the sidewalls and seat. Seatbelts are from FineMolds, paint is mostly Model Master except for the RLM 02 which is White Ensign. Decals came from the Kagero Topdrawings book on the Bf 109E. Thanks to Carl and Martin for the correct canopy. I'm happy with the way it turned out although there are a couple of small things I wish I had corrected.
© John Bardwell 2014
This article was published on Thursday, September 04 2014; Last modified on Thursday, September 04 2014
