Revell 1/32 Messerschmitt Bf 109G-6
By Mauricio Castro
Finally there she is, Hans Langer mount as depicted in the EagleCals EC132. The scheme is quite standard except for the white color fuselage band and rudder which along with the big white 12 make the aircraft look quite attractive. Painting strategy with pre and post shading allow me to give volume with different filters and shades.
The kit, well there are different opinions, but from my perspective it’s a great value for the buck, fit is very good though there are the fuselage joints on the fwd wing root which isn’t natural at all but can be solved with a bit of putty.
Wheels are MDC and harnesses of injected plastic from Finemolds and beside the decals the kit is OOB.
Build thread is in the forums.
© Mauricio Castro 2014
This article was published on Monday, May 12 2014; Last modified on Monday, May 12 2014
