Revell 1/32 Heinkel He 162
By Wouter Groenen
Seven years ago I paused with modelling, you know, because of life. I stopped with armor and now I started with large scale planes. So this is my first kit in 7 years. Lots of mistakes, but the result is not to bad in my opinion. Learned a lot, not the least that I need more patience. Also building armor is more forgiving then planes. If you make a mistake with armor you can always cover it up in mud...
The build process can be found in the forums.
© Wouter Groenen 2014
This article was published on Friday, May 09 2014; Last modified on Sunday, June 10 2018
