Hasegawa 1/32 Bf 109F-4 Trop - Captured by SAAF
By Sinuhe Hahn
AX-? is probably the most famous Bf 109 captured by the SAAF. She was captured by 1 Sqn (hence, the AX codes), test flown quite extensively until pranged…
Her sister is stored at the War Museum in JHB.
A bit rushed to get in finished before year's end. Not quite happy with some parts…oh well.
I lost one of the exhausts - in the F-4 Hasegawa has each individual exhaust as a single item…anyhow, it went walk about after bouncing off the table…so I had to use a spare set of Ki 61 exhausts.
© Sinuhe Hahn 2013
This article was published on Sunday, January 05 2014; Last modified on Sunday, January 05 2014
