Hasegawa 1/32 Bf-109G-14/AS
By Frank Daniels
This is my Hasegawa 1/32 Bf-109G-14/AS, modified from their G-10 kit. It is mostly OOB with rescribed hatches per G-14/AS specs, and includes lead foil seatbelts, main gear wiring. I drilled out the kit exhausts, and thinned the blade openings on the kit spinner. I also thinned and opened up the kit supplied ETC rack, and built an actual rack from styrene bits.I painted it with Tamiya acrylics, and used Eagle Editions decals. Let me know if you need any other info!
© Frank Daniels
