Trumpeter 1/32 F-100D
By Rick Bellanger
Here is my latest conquest. It is the beautiful F-100D from Trumpeter. The model went together quite well. I used the Combat Models (AKA Black Box) cockpit set. This was a little hard to install but well worth the effort. Alclad ll was used for the bare metal finish and all I can say about this stuff is "How good it is and quite easy to use"! I used their black primer then painted the base coat using their aircraft aluminum. From there many other shades were used to achieve the effect I was after.
Cutting Edge Decals where applied and had no problem using them.
Hope you enjoy.
© Rick Bellanger 2007
