Airshow Models Extra 300
By Barney Dunlevy
Here's the latest model in 1/32 scale...resin and brass...and it is terrific. The basic Red/White/Blue scheme is the standard factory with Chilean Air Force "Halcones" markings added. Both the civilian registration decals and the "Halcones" decals are included in the kit.
Everything goes together without the usual limited run type problems; the castings are very crisp and well engineered.
I'm working on another, Denny Dobson's aircraft for the Brit population and when finished photos of both aircraft will be used in the construction manual. I've changed the format in the manual with more pics in logical sequence and I've kept the text to a minimum.
Photos taken with a Nikon Coolpix 990...and waiting for the new Nikon 8700.
© Barney Dunlevy 2004
