Hasegawa 1/32 P-40K
By Paul Dunham
Here is my recently finished Hasegawa P-40K. I used Barracudacals markings and scratchbuilt wheel well linings out of paper. It would have qualified for the mostly OOB group build if I had not messed up one of the kit tires and replaced them with Eclipse resin tires (which fit perfectly).
The pilot figure comes with the kit (I think that it may be in all the 32nd Hasegawa P-40s).
I made the wheel well liners out of card stock. Once they were installed I dampened the paper and worked wrinkles and undulations into it with a stiff brush.
© Paul Dunham 2013
This article was published on Monday, July 08 2013; Last modified on Monday, December 19 2016
