Warbirds | 1/24th Resin accessories for the Trumpeter or Airfix Spitfire
Reviewed by Dave Wadman
Well-known for his range of quality 1/32nd Spitfire conversion kits and aftermarket resin accessories, Vasko Barbic of Warbird Productions U.K. has recently produced the first two resin accessories for use with either the recently released 1/24th Trumpeter Spitfire Vb or Airfix kit: Rotol propeller blades and spinner and an accurate seat and mounting frame.
These well-cast and accurately detailed castings require virtually no clean up and are direct replacements for the existing kit parts so no additional work is required when fitting to the model. Hopefully these releases will signal the beginning of a series of accessories for these big Spitfire kits. Highly recommended for anyone building either the Trumpeter or Airfix offerings.
© Dave Wadman 2003
