Scale Aircraft Conversions | 32089: F4F Wildcat Landing Gear
Reviewed by Ray Peterson
A recent release from Scale Aircraft Conversions is this new accessory set for the Trumpeter 1/32nd Wildcat kits from a few years ago now. The set includes the main landing gear and tail gear as well as retraction arms.
This set is simply meant to be a direct replacement for the kit’s plastic landing gear, providing the modeler the option to go with white metal instead of plastic. While the casting is quite good, most of the details are unchanged and any defects of the kit parts, such as molding seams, are therefore replicated on the SAC gear. The SAC gear also replicates the kit’s tail gear fork.
I still am not happy with the softness of the alloy used. The Wildcat has spindly gear. The SAC gear is of course just as spindly as the kit gear and bends easily. I am not sure the SAC gear will not bend over time. Also, some of the smaller parts may be hard to use. Clean up of seams will be difficult, and the soft alloy will bend so easily it may be hard keeping them to stay straight. The modeler may be better off using the kit parts for these smaller parts if they use the SAC gear.
Only Recommended if needed to replace broken kit parts.
Thanks to Scale Aircraft Conversions for the review set.
© Ray Peterson 2015
Sprue Brothers Roll Models HobbyLink Japan Lucky Model
This review was published on Sunday, August 09 2015; Last modified on Friday, August 14 2015
