Hasegawa | 1/16 Sopwith Camel (Part One)
Reviewed by Mike Swinburne
With the centennial of the beginning of World War One coming up in 2014, Hasegawa has released a completely new-tool Sopwith Camel in large 1/16 scale; kit number MU01. Like older 1/8 scale kits, this new kit is a complete skeleton model showing essentially every detail otherwise hidden on an aircraft covered with fabric. Unlike the older 1/8 scale WWI aircraft and 1/16 Wright Flyer however, the construction does not involve the use of any wood or metal - this kit is completely injection molded.
Just how large is a 1/16 scale Camel? Read on to find out!
Part One of the review shows the overall layout of the sprues and what you can expect from the kit as a whole (hint: a lot!).
Part Two will show you some closer-in detail of some notable parts of the kit, to give you a better overall idea of what your money is really buying (again, hint: a lot). The only details I can spot that are missing are seatbelts and turnbuckles.
In the box, you get sprues molded in multiple colors (dark tan, light tan, beige, black, clear, and satin silver-plated), plus rubber tyres, copper wire, thread, aluminum tape, and full-size detail plans to assist with your rigging of the model. This is not a shake and bake kit, and definitely not for beginners, but anyone with patience and some experience with large and detailed kits should have a great time building this kit.
The box:
Sprue A: Fuselage frame sides with landing gear and wing struts molded on
Sprue B: Upper wing, horizontal stabilizer, forward fuselage "wood" panels
Sprue C: Lower wing, elevators, rudder
Sprue D x2: Wing ribs, ailerons, etc
Sprue E: Outer struts, top fuselage parts, cockpit floor, control panel, tail, propeller
Sprue F (satin silver-plated parts): cowling parts, fuel tank, oil tank. I cannot stress enough how nicely done the plating on this sprue is. if you have ever seen the silver-plated release of Tamiya's 1/2 P-51 or 1/48 F-84, it's identical to those - gorgeous.
Sprue G: Engine, gun bodies, shell ejector chutes
Sprue J: Cockpit detail parts
Sprue L x2: Gun barrels, engine parts
Sprue K: Seat
Sprue M: Wheels x2
Sprue N: Axles, rudder
Sprue Q: Clear parts
Rubber tyres and other miscellaneous items:
Color Diagram, full-size plan views for rigging, and decals:
So, how large will this kit be when assembled? Well here are the full-size included plans compared to the HK Models 1/32 B-25. You may need a bigger shelf!
© Mike Swinburne 2013
This review was published on Monday, June 24 2013; Last modified on Monday, June 24 2013
