Barracuda Studios Announces 5 New 1/32nd Scale Resin Products
Barracuda Studios is proud to announce the release of 5 new 1/32nd scale products in the BarracudaCast resin detail set line. These sets are now up on the website and available for order.
These sets are designed to replace the supplied plastic wheels of all 1/32nd scale Bf 109G-5 through K-4 kits. That trumpeter kits, with their rubber tires make these new wheels a must. The Hasegawa G/K series and the new Revell 109G-6 kit will also benefit, as these wheels are more accurate, petite and detailed than what comes in the box. A wide range of styles allows you to match the wheels and tires of the exact 109 you are building.
BR32070 - 1/32 - Bf 109G Wheels - Ribbed Hub, Ribbed Tire
This set consists of a pair of super detailed, accurate resin mainwheels as fitted to the Bf 109G-5 through G-14 series aircraft. These wheels represent the very common early fit of the ribbed tire fitted to the ribbed hub. Will upgrade any 1/32nd Bf 109G kit, such as Hasegawa, Revell, and Trumpeter kits. Master patterns by Gunnar Jansson.
http://barracudacals.com/proddetail.php?prod=BR32070&cat=43
BR32071 - 1/32 - Bf 109G Wheels - Ribbed Hub, Smooth Tire
This set consists of a pair of super detailed, accurate resin mainwheels as fitted to the Bf 109G-5 through G-14 series aircraft. These wheels represent the fit of the smooth tire fitted to the ribbed hub. Finely rendered raised tire data is featured. Will upgrade any 1/32nd Bf 109G kit, such as Hasegawa, Revell, and Trumpeter kits. Master patterns by Gunnar Jansson.
http://barracudacals.com/proddetail.php?prod=BR32071&cat=43
BR32072 - 1/32 - Bf 109G Wheels - Plain Hub, Ribbed Tire
This set consists of a pair of super detailed, accurate resin mainwheels as fitted to the Bf 109G-5 through G-14 series aircraft. These wheels represent the later fit of the ribbed tire fitted to the plain, ribless hub. Finely rendered raised tire data is featured. Will upgrade any 1/32nd Bf 109G kit, such as Hasegawa, Revell, and Trumpeter kits. Master patterns by Gunnar Jansson.
http://barracudacals.com/proddetail.php?prod=BR32072&cat=43
BR32073 - 1/32 - Bf 109G Wheels - Plain Hub, Smooth Tire
This set consists of a pair of super detailed, accurate resin mainwheels as fitted to the Bf 109G-5 through G-14 series aircraft. These wheels represent the later fit of the plain tire fitted to the plain, ribless hub. Finely rendered raised tire data is featured. Will upgrade any 1/32nd Bf 109G kit, such as Hasegawa, Revell, and Trumpeter kits. Master patterns by Gunnar Jansson.
http://barracudacals.com/proddetail.php?prod=BR32073&cat=43
BR32074 - 1/32 - Bf 109G-10 and Bf 109K-4 Mainwheels
This set consists of a pair of super detailed, accurate resin mainwheels as fitted to some Bf 109G-10 and most K-4 series aircraft. These wheels represent the the wide, smooth tire fitted to the plain, ribless hub. Finely rendered raised tire data is featured. Will upgrade any 1/32nd Bf 109G-10 and K-4 kit, such as Hasegawa and Trumpeter kits. Also replaces the mainwheels for the He 162. Master patterns by Gunnar Jansson.
http://barracudacals.com/proddetail.php?prod=BR32074&cat=43
All 5 sets are currently in production, and we are taking orders now at our website: http://barracudacals.com/index.php.
Happy modelling! Roy
This article created on Wednesday, July 10 2013; Last modified on Wednesday, July 10 2013
