HpH Models 1/32 de Havilland Sea Hornet NF.21
By Warren Zoell
Here are some images of HpH Models 1/32 scale de Havilland Sea Hornet NF.21.
If you do decide to build this kit I would recommend that one should be very careful when removing the large amounts of support resin around the main wings. One is left with very delicate pieces and can be easily broken. Though the interior is extremely detailed it’s pretty much all in black making it difficult to see. Which is a shame from a model building point of view.
A must-have if you’re into post war British aircraft.
© Warren Zoell 2017
This article was published on Wednesday, November 29 2017; Last modified on Wednesday, November 29 2017
