Eduard 1/32 Messerschmitt Bf 109E-1 "Profi Pack"
By Thierry Laurent
KIT DATABASE ENTRY:
http://www.largescaleplanes.com/kitdb/details.php?kit=930
TWEAK LIST VERSION 1.0 (publication date: February 2014)
The following list is intended to help modelers in improving scale accuracy of an airplane model replica. In no way is it intended to support or be offensive towards a scale model company.
As such, it is only the result of a progressive process and is in no way intended to be absolute or even comprehensive. Hence, it is intended to focus on commonly admitted discrepancies and will probably not cover some errors. It is up to the modeler to decide whether correcting the listed issues is worth the time and money he will have to invest in the quest for accuracy process.
No aftermarket correction or detail set is mentioned in this document as the availability of such items may be very variable. Hence, refer to other LSP sections to find relevant information. Moreover, aftermarket sets do not necessarily correct all listed issues. Please refer accordingly to relevant documentation.
GENERAL OVERVIEW
NOTICEABLE ENGINE/OIL COOLER ISSUES
NOTICEABLE FUSELAGE ISSUES (from front to rear)
NOTICEABLE WING/WEAPON ISSUES
NOTICEABLE COCKPIT ISSUES
NOTICEABLE CANOPY ISSUES
NOTICEABLE LANDING GEAR ISSUES
OTHER NOTICEABLE ISSUES & MISCELLANEOUS REMARKS
KIT MARKINGS
Four marking options are included in the Profipack edition whereas the Weekend edition only has the second scheme:
REFERENCES
The list of references about the Messerschmitt 109 is an endless one. The list author focused on sources that are more oriented towards plane components rather than plane colors. Many excellent books have been printed about the later topic but this is out of the limited scope of such a list. As such, sources dedicated to Luftwaffe paints and camo, 109s colors or 109s used by Germany allies have not be used here.
Accordingly, the following sources were used to build this list:
Modelling Essentials:
Other References:
© Thierry Laurent 2014
This article was published on Tuesday, November 22 2016; Last modified on Tuesday, November 22 2016
