Special Hobby 1/32 Yak-3
By François Laloux
François had finished in a time span of only 7 days (!) the new Yak 3 by Special Hobby. He found it a very nice kit to build, although some work was needed on the connection between the wing and lower fuselage.
Painting Process
- No pre-shading for me (I sort of abandoned it now), I prefer post-shading
- the first layer of paint is the regular one
- second is a lighter version, sprayed with a cloud pattern
- post-shading is done with Tamiya Smoke + black + brown, highly diluted
- a filter of oil paint id applied after decals + gloss coat, using the dot method (put little dots of paint and use a damped brush to feather it)
- coat of matt paint (Vallejo)
- pigments for fun
© François Laloux 2016
This article was published on Friday, November 04 2016; Last modified on Friday, November 04 2016
