Dragon 1/32 Bf 109E-7 Trop JG27
By Dejan Lukic
I wanted to do this one for long time and finally decided to go through with it.
I used excellent 1:32 Dragon kit an I must say I find it a bit more enjoyable to build than Eduard offering. Really had no problem building this one. All parts come together quite nice and I was a bit afraid of nose section since I had no intention to build it with engine. All that was in need was some careful positioning and the whole area fit quite nicely.
I decided to use Model Master Acrylic RLM 79 since it look more yellowish than enamel paint from same manufacture. I think it gives more realistic look for early Luftwaffe desert Emils, enamel is much more suited for later 109s. RLM78/80 are MM enamel and decals are from Kagero.
© Dejan Lukic 2016
This article was published on Wednesday, August 24 2016; Last modified on Wednesday, August 24 2016
