Revell-Monogram 1/32 McDonnell Douglas F-4G Phantom II USAF (Slatted Wing)
By Thierry Laurent
KIT DATABASE ENTRY:
http://www.largescaleplanes.com/kitdb/details.php?kit=2311
TWEAK LIST VERSION 1.3 (publication date: August 2016)
The following list is intended to help modelers in improving scale accuracy of an airplane model replica. In no way is it intended to support or be offensive towards a scale model company.
As such, it is only the result of a progressive process and is in no way intended to be absolute or even comprehensive. Hence, it is intended to focus on commonly admitted discrepancies and will probably not cover some errors. It is up to the modeler to decide whether correcting the listed issues is worth the time and money he will have to invest in the quest for accuracy process.
No aftermarket correction or detail set is mentioned in this document as the availability of such items may be very variable. Hence, refer to other LSP sections to find relevant information. Moreover, aftermarket sets do not necessarily correct all listed issues. Please refer accordingly to relevant documentation.
GENERAL OVERVIEW
NOTICEABLE FUSELAGE ISSUES (from front to rear)
NOTICEABLE WING/WEAPONS ISSUES
NOTICEABLE COCKPIT ISSUES
NOTICEABLE CANOPY ISSUES
NOTICEABLE LANDING GEAR ISSUES
OTHER NOTICEABLE ISSUES & MISCELLANEOUS REMARKS
KIT MARKINGS
Revell-Monogram decals are good but far from comprehensive regarding stenciling and panel number. However, it is true that pictures of late F-4Gs do not show extensive stenciling as it was the case on seventies/early eighties planes.
REFERENCES
The following sources were used to build this list.
Modelling Essentials:
Scale Plans and TM Extracts:
Colour Pictures & Photofiles:
Other References:
© Thierry Laurent 2016
This article was published on Friday, September 02 2016; Last modified on Friday, September 02 2016
