Revell 1/32 Messerschmitt Bf 109G-6, Early & Late Variants
By Thierry Laurent
KIT DATABASE ENTRY:
http://www.largescaleplanes.com/kitdb/details.php?kit=1974
TWEAK LIST VERSION 1.0 (publication date: September 2013)
The following list is intended to help modelers in improving scale accuracy of an airplane model replica. In no way is it intended to support or be offensive towards a scale model company.
As such, it is only the result of a progressive process and is in no way intended to be absolute or even comprehensive. Hence, it is intended to focus on commonly admitted discrepancies and will probably not cover some errors. It is up to the modeler to decide whether correcting the listed issues is worth the time and money he will have to invest in the quest for accuracy process.
No aftermarket correction or detail set is mentioned in this document as the availability of such items may be very variable. Hence, refer to other LSP sections to find relevant information. Moreover, aftermarket sets do not necessarily correct all listed issues. Please refer accordingly to relevant documentation.
GENERAL KIT OVERVIEW
KIT OPTIONS:
In the “not for use” parts, there are other options:
NOTICEABLE FUSELAGE ISSUES (from front to rear)
NOTICEABLE WING/WEAPONS ISSUES
NOTICEABLE COCKPIT ISSUES
NOTICEABLE CANOPY ISSUES
NOTICEABLE LANDING GEAR ISSUES
OTHER NOTICEABLE ISSUES & MISCELLANEOUS REMARKS
REFERENCES
The list of references about the Messerschmitt 109 is an endless one. The list author focused on sources that are more oriented towards plane components rather than plane colors. Many excellent books have been printed about the later topic but this is out of the limited scope of such a list. As such, sources dedicated to Luftwaffe paints and camouflage, 109s colors or 109s used by Germany allies have not be used here.
Accordingly, the following sources were used to build this list:
Modelling essentials:
Other References:
© Thierry Laurent 2013
This article was published on Wednesday, August 03 2016; Last modified on Thursday, August 04 2016
