Kitty Hawk 1/32 OS2U-3 Kingfisher
By John Smith
Well all I can say is that I thoroughly enjoyed this kit. Fit is great, subject matter is beyond great, and with a little care it will it turn out just the way you pictured. I will say that it is most important to just take your time. I did not use sprue cutters on any part I removed from the trees. I made sure the part was on a flat surface the gave the attachment point a few swipes of my blade just like I was removing resin from a casting block. Also be advised that the alignment pins are a tight fit, but they will seat with a firm push and you will find it hard to get the parts apart when you are test fitting. I have to say that it was very satisfying to get this one done as it had been criticized so.
© John Smith 2016
This article was published on Thursday, June 02 2016; Last modified on Thursday, June 02 2016
