Northrop F-5F from the Revell Kit
By Carlos Corona
Image 01
Background
Since the arrival to México in 1982 the F-5E Tiger II has been the backbone of air defense in México,they formed 401st Defense Esquadron named "The Tiger Knights". Twelve aircraft was bought from the USA, 10 single-seaters, FAM numbers 4001/4010 and 2 two-seaters 4501 and 4502. Ther are armed with two AIM 9 sidewinder, MK 82 bombs and rocket launchers for ground attack missions on their hard points, only two aircraft where lost in fatal accidents in 1984 and 1997.
The model
My idea started because in México a modellers club made an were selling a decal sheet for Tigers in 1/48 and 1/32 in Mexican and Chilean markings, Mexican markings include serials and data for both models E and F. So i took the challenge to make an F model.
I also bought a resin kit made in Mexico by the same model club to convert the F-5 that includes: Shark nose, Leading Edge Extensions "LEX" (like F-20), Dorsal fin, Flaps, and Tail Plane tip (out of production both items!!!).
I didn’t cannibalize another F-5, I only bought the fuselage front pieces, a seat, cockpit floor and canopy actuators from Lodela customer service. Then I carefully studied where to make the cut in both sections to preserve the characteristic curve below the front fuselage section.
I needed the space of 5cm back for the rear cockpit and make cockpit side walls.
Image 02
I scratchbuilt the control panels with sandwich technique, because the model panels don’t match the real thing and rear panels are different, for rear panel I consulted drawings in F-5E in Action Series photocopied them and made a template.
Image 03 Image 04
I also corrected and converted the ejection seats to match the Mexican tiger, with plasticard for head rest and I made cushions from epoxy Plasticine. Seat belts are made from aluminium foil.
Image 05
Also I had to make the "wing fence" that is on the F model, with an exact trace panel cut through the wing then plasticard made fence are placed and glued in the groove, navigation lights was made before painting taking the model part and filling only transparent section, after painting I put a drop MICRO SOL CRISTAL MAKER, when that was dry i painted it with TAMIYA´S clear red and blue.
Note the FAM national insignias and data in a combination of Espanish and English.
The principal differences of Mexican tigers are the dorsal fin, "LEX" and shark flat shaped nose for best maneuverability at high angles of attack, and also the VHF antenna for communications.
Of course I vac-formed the new canopies and made the middle structure of the canopy section from plasticard and metal wire.
Image 06 Image 07 Image 08 Image 09 Image 10
Painting
I painted the Mexican tiger in standard SEA scheme colors: Fs 34079, Fs 34102, Fs 30219 and camouflage pattern are a variation of Standard US Navy Aggressor Scheme (wrap around in Mexican planes.) I used Gunze Sangyo Colours. Shark nose and tail plane tip are paint in Olive Drab, the rear section is painted with Model Master Aluminium Plate Buffing Metalizer, landing gears and wheel wells in matt aluminium, central fuel tank are overall in green Fs 34079.
Future project is a Chilean Hawker Hunter in 1/32.
© Carlos Corona
This article was published on Wednesday, July 20 2011; Last modified on Thursday, June 14 2018
