Hasegawa 1/32 Kawasaki Ki-61 "Hien"
By Olivier Barles
Here are a few pictures of my recently assembled Kawasaki Ki-61 "Hien" from Hasegawa.
This time, it has been a very "quiet" work with only "a minor need of a bit of putty" for the joints between the wings and the fuselage.
Otherwise, no surprise: some very good Hasegawa stuff providing thin and realistic structures lines and very precise rivet points.
The good thing with such a plane is the choice of colors and markings where you can "extensively" use your "weathering skills"! This one was no exception.
The best part of the assembly was indeed finding as much as possible the right balance in weathering / aging.
The aim is to give the model the appropriate look that could fit into the most realistic appearance, showing a plane with already a long operational life but with "no excess".
As a matter of fact, weathering and aging too much can somehow become a systematic process and in the end, results give the opposite by showing up an artificial aspect...
Hope I could do it this time!
Image 01 Image 02 Image 03 Image 04 Image 05 Image 06 Image 07 Image 08 Image 09 Image 10 Image 11 Image 12 Image 13 Image 14 Image 15 Image 16 Image 17 Image 18 Image 19 Image 20
© Olivier Barles
